Cor-Ten A equivalent to ASTM?
What is the equivalent of Cor-Ten A to ASTM?
RE: Cor-Ten A equivalent to ASTM?
I think there are two different specs that are called Cor-Ten.  ASTM A588 is one, I believe, but don't recall the second.  It may have been a plate/ sheet difference.
Took some googling around, but it seems A588 Gr. A is the Cor-Ten B, which is a plate spec.  Cor-Ten A is a sheet spec, and is A242 Type 1.  I also find a reference to A606 Type 4 as Cor Ten A.
