steam jacket
steam jacket
steam jacket
I am trying to model a steam jacket in Compress, but am having no luck.  In this particular case we are using NPS24 pipe with plates at each end to jacket NPS18 pipe.  The NPS18 pipe will have nozzles that will project thru the jacket.  Any help would be greatly appreciated. Thanks.
RE: steam jacket
You have to model an inner vessel (18" with external pressure and internal vessel) in one file.  Then model the 24" jacket in another file.
Compress does not let you mix the two up in the same file.
