Edrawings error massage
Hi All,
Here is a an edrawings question. Have any of you seen this error before. I cant open a .sldprt in edrawings. I get this message. I have reinstalled it and still get this message.
 Any ideas?
Error message : No Display Lists Are Available in the file.
RE: Edrawings error massage
Do you have AutoCAD installed? There may be a conflict. I have the same issue after I installed AutoCAD, SolidWorks and Inventor. I had to completely remove eDwgs, restart pc, then install.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
Yes I do have AutoCAD. Do I have to remove AutoCAD and reinstall Edrawings. Or Just reinstall Edrawings?
Uninstall eDwg. Reboot, then reinstall.
Chris
AutoCAD 06/08
Try resaving the part from SolidWorks. The display list is data within the part file, and it may need to be regenerated.
Eric
