Reference book or handbook for corrosion rate
Could anyone recommend reference books or handbooks or other available and believable materials about corrosion rate to determine corrosion allowance for pipe and pressure design? Thanks a lot.
RE: Reference book or handbook for corrosion rate
a general database for chemicals and fluids id the Cor-Sur of Nace that you can access at Knovel website.
http
here you can find corrosion rate for almost everything.
then there are a lot of books..
Handbook of Corrosion Data ASM
http://www.normas.com/ASM/pages/6407.html
these sources can give you advice for corrosion rate but you should be aware that you have to know how to use these data..and how to evaluate the corrosion mechanisms active in your process..
S.
S.
Corrosion Protection & Corrosion Control
There are a number of good ones from AMS depending on your specific field of interest.
Plymouth Tube
Plymouth Tube
<http://www.outokumpu.com/pages/Page____20240.aspx>
which is in your pipe.
One of the most complete : dechema corrosion hanbooks,
if you can afford them.
If you use Stainless steel, ask directly to steel manufacturers.
rgds
jean-luc
