HEC-RAS modeling flow into a standing body of water
Is there a way within HEC-RAS to model flow into a standing body of water? For instance, I have a case where I have culverts terminating in a standing body of water (lake). I have a cross-section of the lake and a known water surface elevation for the lake. The problem is when using the lake for the downstream boundary condition, HEC-RAS wants to put a flow to it, when, in reality, there is no flow in the lake.
In my particular situation, the culverts are flowing in the subcritical regime. When HEC-RAS puts a flow to the downstream lake boundary condition it comes up with a supercritical answer which creates a discontinuity with the upstream subcritical regime. The model then defaults to critical depth for the downstream boundary condition.
In addition, standing water will act like an energy dissipator for the incoming flow.
Is there any way to simulate this in HEC-RAS?
RE: HEC-RAS modeling flow into a standing body of water
I know the starting wse elevation but the question is, is there a way to simulate standing water? HEC-RAS takes the starting wse and calculates a flow for it. That's not what I want. I want to model the effects of flow dissipating into standing water.
Thanks.
