Design Manager & Engineering Manager
what is the difference between the Design Manager and Engineering Manager and how far are they from the project manager and program manager. and is there any courses for the engineering (civil) management?
RE: Design Manager & Engineering Manager
Others may have worked in a different hierarchical structure so you may end up with numerous differing responses.
However, as PSE said, job titles are almost meaningless it's the job description that starts to get a bit more usefull and even then the job someone actually does doesn't necessarily match their job description.
KENAT, probably the least qualified checker you'll ever meet...
