MID-Range IR Thermographic Camera
I'm looking for a mid-range IR (around 3-5 microns) thermographic camera that can interface, but does not need to have a high resolution, just something that can feed images back to a computer. It will be used to observe lab rats through a polysulfone cage, so it has to be mid-range IR (from 8-12 microns the transmissivity of polysulfone becomes very poor). So far the range of thermographic cameras i've seen has had a huge disparity between both price and functionality. Either a hand held camera for 1000 bucks that cant interface at all or 13000+ cameras that are overkill for the application I had in mind. If anyone knows where I could find a camera that sits inbetween that sort of range that'd be great!
RE: MID-Range IR Thermographic Camera
Perhaps these folks will have something that will work for you. At a glance I found 7 to 14 microns, "less than" $5K to "less than" $6K.
http://www.aas2.com/index.htm
Harold
SW2008 SP3.0 OPW2008 SP0.1 Win XP Pro 2002 SP2
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
