Linear Axis Cartesian Robot
3
I was wondering if anyone knew where I could find a linear axis cartesian robot (belt driven or ball screw, it doesnt matter) for cheap, ie. around 1500 dollars. It will only have to support very light loads (around 2-5kg) and have an effective stroke of around 1500-1800mm. Most of the products i've seen have been made for more rigorous use and are priced as such. If anyone has any idea of where i could find one that'd be great!
RE: Linear Axis Cartesian Robot
Speed?  Positional accuracy?
Speed not a concern (1 m/s or even a little less)
It should have a repeatability of at least 0.1mm
Thanks MintJulep
No idea how much a CMM runs, but it seems as though one could be modified to more than meet your speed and position.  When you say "cheap", are we speaking of $xxx.xx (US) or $XXXX.XX (US)...obviously fewer is better, but how much does quality matter.  Lego's MindStorms products provide some interesting capabilities for less than $100.00 (US), but the reliability is for that of children...
The cheap way to get two-axis motion is to bolt two linear actuators to each other at right angles.
Simple ball screw or belt linear actuators are almost a commodity item.  Thomson, THK, Linac are a few names.
I'm not saying they don't exist, but I've never seen a CMM that was self- propelled.  I.e., you had to drag the point around by hand.
I get the impression Hansell wants 3 axes, not 2.
1m/s to 0.1mm throughout a 1.5m cube is actually a pretty stiff requirement... especially for a gantry, which would itself occupy a 3m cube, roughly.  That's a lot of machinery.
$1500 won't buy you one axis, unless you're shopping in a junkyard, in which case you might have to relax a requirement or three.
For that order of magnitude of money, you might be able to do a 15cm cube with hobby CNC milling stuff.
Mike Halloran
Pembroke Pines, FL, USA
You need to look at these sites to see what's available and then make rounds on the surplus sites. A times you can find these components on the surplus market
All types of linear drives
http://www.amacoil.com/HTML/az_index.htm
linear belt drive
http://www.macrondynamics.com/
Look at the ZF1 product. Look around this site
This is a very good site.
http://www.techno-isel.com/Tic/LinMoProducts.htm
Very long linear drives
http://www.tolomatic.com/products/item_detail.cfm?tree_id=98
Thanks for all your input guys.
I actually think the ZF1 would be very suitable (pretty cheap too, $875.00 is the quote i got in case anyone is wondering).
