VB "Select Case" Syntax
Howdy All,
I'm trying to set up a VB Select Case construct and seem to be missing something.
Attached is a SW Macro I've been trying to set-up. I think I'm close or way-off
Can anyone help me with this?
Tobin Sparks
www.nov.com
RE: VB "Select Case" Syntax
Thanks for your responce. I have been looking in all kinds of help files
Can anyone help?
Tobin Sparks
www.nov.com
CODE
Also, can't repeat values for Case statements (i.e. can't have two "Case 1" statements)
CODE
If Len(TextBox1.Text) = 0 And Len(TextBox2.Text) = 0 Then SelectOpt=0
' TextBox1 only
If Len(TextBox1.Text) > 0 And Len(TextBox2.Text) = 0 Then SelectOpt=1 ' TextBox2 only
If Len(TextBox1.Text) = 0 And Len(TextBox2.Text) > 0 Then SelectOpt=2' TextBox1 & TextBox2
If Len(TextBox1.Text) > 0 And Len(TextBox2.Text) > 0 Then SelectOpt=3
CODE
Case 0 ' NO Selected Options
MsgBox ("No Text entered! "), vbInformation, "Make Note2"
Case 1 ' TextBox1 only
Set AddNoteLines = swPart.InsertNote(Me.TextBox1)
Case 2 ' TextBox1 only
Set AddNoteLines = swPart.InsertNote(Me.TextBox2)
Case 3 ' TextBox1 & TextBox2
Set AddNoteLines = swPart.InsertNote(Me.TextBox1 & Me.TextBox2)
Case Else ' Catch all error
MsgBox ("Unknown Error"), vbInformation, "Make Note2"
End Select
Thanks for your response AGAIN!
Yes I was trying to use "SelectOpt(3)" as an Array.
Do you know how I can make it work that way?
Maybe it's not the best way to go in this situation.
I really appreciate your help.
Tobin Sparks
www.nov.com
P.S. you may want to add a space or carriage return when you concatenate the text boxes.
CODE
Thank you very much for all your help!
Tobin Sparks
www.nov.com
