Engineering-International.com
Has anyone purchased or used the spreadsheets from this website? It looks to have quite a few spreadsheets with code references with the calculations. The author is Daniel T. Li.
Thanks for the input.
RE: Engineering-International.com
How do you know it (the composite beam design) works well? Did you have some well known, or well worn, or trusted solutions to compare to? Or did you do a hand calc?
