ASTM # for EN 10336
ASTM # for EN 10336
I am looking for a mill in the USA that can produce a HSLA steel with the code EN 10336.
This is a German spec and no ASTM equilivant has been provided. If you are familiar with this steel, can you provide me with a cross reference to relate this steel to?
I have done a key word search and checked FAQ on this forum and didn't find what I was looking for. I am new to this forum so if I have missed something, please advise.
Thank you for your help.
RE: ASTM # for EN 10336
http://www.cen.eu/cenorm/homepage.htm
There are multiple types of steel contained in this document, so you will need to provide more information to get an accurate answer.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The complete reference on the print calls for:
STAHL EN 10366- 1.09858 +ZE+A+o +DBL4062.514
I tried to input this into the CEN link you provided in the previous thread but no results were found.
Does this give you what is needed to fine turn your reply for an even more accurate answer?
Warm Regards,
Robert
This is cutting edge steel technology. There is no US mill producing complex phase steel. You need to work up the supply chain and make contact with the original specifier. Together, you can develop a steel supplier who can provide this material to you.
Cory
Try contacting ThyssenKrupp Steel NA Inc. (http://www.tksna.com)
950MPa tensile grades are available in US but as a dual phase grade rather than complex phase and the sizes will be limited. See SAE J2340 for comparison.
The thickness is .078" (2.0mm). The forcasted production currently calls for 650 tons per year.
