wire edm cutting conditions
Currently I am trying to machine a slot in a stainless steel tube using a fanuc alphaoic wire edm. Curently the wire comes in at one end of the tube and erodes out a slot then exits the tube the same way it came in. Im trying to reduce the width of the slot that the wire is creating. Im using 0.25mm wire which is cutting a 0.35mm slot. I need to cut a 0.3mm slot. Does anyone have any idea which cutting conditions i should change to reduce the spark gap?
cheers
cheers
RE: wire edm cutting conditions
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
