Bar Stock scource needed
I am in need of 2 different sizes of bar stock.  I have print requirements that restrict my material to the following:
AISI 5115
AISI 5117
16MnCr5
Doe anyone know where I can source this round stock?  Are there any specialty metal shops in the US that carry this?
Any help is appreciated.
TIA.
RE: Bar Stock scource needed
What is your volume?  If it is large enough, then you could work with Republic Engineered or the ArcelorMittal location in East Chicago, IN.  They could definitely make it for you.
http://www.republicengineered.com
http://www.arcelormittal.com
If your volume is smaller, then maybe Kreher or ThyssenKrupp might be able to get it, but not definite.
http://www.kreher.com
http://www.tkmna.thyssenkrupp.com/tkmna/index.htm
or you could try one of the MANY members of the Metal Service Center Institute and hope they will work with you.
http://www.ssci.org/memberDirectory/index.aspx
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Macsteel is another mill source for high volume applications.  They DEFINITELY produce these grades as bars.
