Serviceability using the Canadian Code
Usually I calculate the deflection of a beam using live load only or dead and live load and compare it with a limit that is a function of the length of the beam over some number (typically L/360 and L/240.) Or if I'm checking the deflection of a column, I only consider wind load when comparing it to the drift limit.
However, looking at an old design brief, I observed several load combinations used for serviceability and I am not sure where these combinations are coming from:
1.0D + 1.0L + 0.5S
1.0D + 1.0S + 0.5L
(The above combs are taking into consideration both snow and live)
And several other load combinations that I will post tomorrow when I am at work
And for wind:
1.0D + 1.0W
(The above is taking into consideration dead load when checking lateral drift)
This could be very trivial, but I best verify and understand this instead of doing something wrong for a very long time.
1.0D + 1.0L + 0.5S
1.0D + 1.0S + 0.5L
And for wind:
1.0D + 1.0W
