Extrude problem in NX 4.0.4.2
I created
1) 2 circles in single sketch, (both circles are separate, in the sense, neither one inside other, nor crossing each other)
2) created extrude by selecting "feature curves" selection intent, so now you can see single extrude feature in the part navigator.
3) Now selected instance command-> circular array, i am unable to see the extrude in the list that I had created in step 2!!
RE: Extrude problem in NX 4.0.4.2
The workaround is that before you attempt to create the Circular Instance 'Feature' array, you use Format -> Group Features... select the Extrude feature and give it a name, and then Instance array this named Feature Group.
Of course for NX 5, you wouldn't even use the Instance Feature function but rather Instance Geometry which allows you to create Instances of ANY geometric object, whether it's a feature or not.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
NX Design
Cypress, CA
