Calculating Methane Flow Rate In Pipe Line
I know there is the Panhandle A and B And Weymouth calculations but need a copy or explanation of formula.
J. D. Jackson B.S. M.E. & B.S. E.E.
TransContinental Engineering
RE: Calculating Methane Flow Rate In Pipe Line
A Tutorial on Pipe Flow Equations http://www.psig.org/papers/2000/0112.pdf
Fundamentals of Compressible Fluid Mechanics http://www.potto.org/text.pdf
Flow of Compressible Fluids http:
