Question about GE stator bushings
  I am installing the stator bushings on an older GE generator.  Under the CTs, there is an aluminum baffle with a silicone seal to go around the bushing porcelain.  Three of the silicone seals fit tightly aroung the porcelain; three of the seals leave about 1/4 inch gap around the bushings.  Can someone tell me the difference between the two seal sizes, and what the seals are used for?  thanks
