Powder coating and 7075 Al
I have read a few articles regarding negative effects that high temperature powder coating may have on heat treated aluminum. In this case I am specifically interested in 7075-T6. The application is in a bow riser, (archery handle. I am interested in possible changes in mechanical properties and also longer term fatigue resistance.
I am aware that lower temp options such as UV cure powder is available but I want to test the validity of the high temperature information. One example is that aluminum diving tanks may not be coated using this process due to failures. Any comments, experience and specifc refereneces would be appreciated!
Mcnab
Mcnab
RE: Powder coating and 7075 Al
McNab
