J-integral : how to set the "step" between the succesive contours
Hi everybody,
I am modeling a "seam" crack inside the geometry and i would like to compute the J-integral of that crack. So what i did is that i defined the crack tip and the direction of the crack growth.
The problem is that when i take a look at the results the first contours return quite good values but the successive contours return a value almost equal to zero as if these last contours were surrounding not only the crack tip but also the second crack tip (this is a crack inside the geometry and thus it has two crack tips) and thus the whole crack (see picture).
How can i force a kind of "contour step". What i mean is how can i impose the successive contours to only surround the crack tip and not the whole crack?
Indeed my crack is very small compared to the global geometry of the model but i need to compute the J-integral of that small crack.
I am using a very refined mesh but it doesn't help...
Malik
RE: J-integral : how to set the "step" between the succesive contours
Actually, you can visualize the contours in Visualization Module ->Tools->Display Group->Create
Select "Nodes".  ABAQUS creates node sets for subsequent contours. (Check "Highlight items in viewport")
Usually the first contour gives bad results. The value should converge in 3 to 5 contours if the mesh is good.
Thanks Xerf,
You are always very helpful.
Malik
