What is a Droler?
What is a Droler?
What is a Droler?
I did not make up this word.
I have seen it in a catalog somewhere a year or two ago.
I even wrote Droler on a container with a tool that looks similar to a Dreamer (Driil/Reamer).
Niether Google search nor eng-tips search on this forum gave results.
RE: What is a Droler?
Bless your pea pick'n little heart unclesyd.
The pdf comes up with the first page of center drills but then locks up my computer so that I cannot locate the find (search)function for which I assume you are referring.
The lockup is likely a problem with my computer temporarily experiencing a low baud rate.
Could you be so kind as to tell me the bass tool definition of Droler?
From the last page of the pdf:
"ONE PASS DRILL/REAMER COMBINATION"
Mike Halloran
Pembroke Pines, FL, USA
Thank you Mike.  Even on this faster computer at work it took a while to scroll to the last page of the pdf so I appreciate youre specific directions.
The function is the same as a dreamer but probably the geometry slightly different.  I will look up the dreamer specs and compare just for information.
