welding P1 to P4
welding P1 to P4
welding P1 to P4
I am looking for input on the welding of carbon(P1) to P11 chrome(P4)?
RE: welding P1 to P4
flight23,
It is done on regular basis.  Shops have weld procedures to do this on pressure vessels and piping.  The requirements for pwht will vary depending on which code, sizes, thickness, etc.  If this is on code equipment or piping, then you will likely need to document WPS, qualify PQR and qualify your welder WPQ.
What kind of input??????????????????????????
what is the weld wire used for this application?
The weld wire can be one of several choices - it can be carbon steel or it can be low alloy. It depends on specific application, service temperature, stress, etc. For example;
SFA 5.18 ER70S-2 through 6
or (lower temperature service, and the strength matches the P1 base metal strength)
SFA 5.28 ER80S-B2 (higher temperature service, and the strength and corrosion resistance are a match to P4 base material) or even ER80S-D2 or E90S-D2 (where you have even higher strength).
