clarification on damping broadening peak
I came accross an old thread and wanted to make a small comment, but thread is closed:
Here is the thread
http://www.eng-tips.com/viewthread.cfm?qid=160351
It was stated:
Quote:
Bear in mind that damping will broaden the peak as well as reducing its height, so increasing the damping can actually increase the response at a particular speed.
This seems incorrect to me, at least by study of a SDOF system:   Here is an example (which I'm sure is nothing new to anyone here).
http://home.comcast.net/~electricpete/eng-tips/SDOF_VaryDamping.pdf
Increasing the damping does broaden the shape of the peak, but the amplification at any given frequency is lower as we increase damping, correct?
RE: clarification on damping broadening peak
You are right of course, for an SDOF system.
"so increasing the damping can actually increase the response at a particular speed."
was wrong, for your simple SDOF system.
BUT, there are many more complex systems where adding damping does increase the off-resonant response, eg increasing the damping levels in a shock absorber. You see the same in engine mounts, diff mounts and suspension bushes.
Nice catch.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Thanks. That makes sense.
In fcat thinking baout it it seems to depend on whether you have a base excitation system, or are looking at the transmissibility through a system.
So, in the case of a driveshaft, it might well be closer to yuor SDOF example.
Cheers
Greg Locock
