Threaded connections makeup procedures and standards in the Oil and Ga
I will like if someone can help with the Identification and classification of most used connections for different types of pipes: Drill Pipes, asing and Tubing.
How are each of this pipes makeup procedures different? please with the description of each of them.
What is the standard and recommendations for makeup procedures in general?
What are most the most typical plots for the makeup procedures?
Thank you, pls reply asap because it is somewhat urgent.
