Plywood Diaphragm Shear Capacity
I have been using the publication from APA to determine plywood diaphragm shear, which involves long formula.  Do you know if there is any place where I could find a table showing allowable 3/4" plywood diaphragm shear, like the one in IBC?
Thank you in advance.
RE: Plywood Diaphragm Shear Capacity
On Page 12, Table 8 of an APA Design / Construction Guide for Non-Residential Roof Systems from 1981, the recommend shear capaciyties are the same as for a 5/8" panel.
The distinction they make is that the 5/8" panel is a "Veneer Faced Panel", whereas the 3/4" panel is an "Other Panel".  This is going back quite a ways, but it seems that using the 5/8" values would be OK in lieu of the calculating you were mentioning.  This is proobably not what you wanted to hear.
Mike McCann
MMC Engineering
