Calcium-Ammonium Nitrate Solution
Hi everybody, I would like to know if somebody has any information regarding viscosity, specific heat and thermal conductivity of calcium nitrate/ammonium nitrate aqueous solutions (both solutes in water). I'm designing a helical coil to heat this solution (65% Ca(NO3)2, 6% NH4NO3, 29% Water, %w/w) and I need those properties in order to evaluate the heat transfer. I also have to calculate pressure drops for this solution.
Thanks so much for your help.
RE: Calcium-Ammonium Nitrate Solution
http://www.olisystems.com/index.shtml
HTH
