Controlled pumping out of a above ground storage tank
I want to pump storm water out of a aboveground storage tank using a air diaphragm pump. The outlet of the tank would be roughly the same elevation as the inlet to the pump. I want the pump to turn on at a certain height and turn off at a certain height. How can I do this with installing a float system within the tank? Any ideas?
RE: Controlled pumping out of a above ground storage tank
Why not just have a valve that opens and closes at the prescribed water levels?
Stephen Argles
Land & Marine
www.landandmarine.com
For example, IR has liquid level sensors for their diaphragm pumps.
http:/
Ted
If you DID mean that you don't want to use a float switch or anything internal to the tank, you can use a pressure sensor at or near the tank bottom. Best would be a good analog sensor with a controller, but you might be able to accomplish it with a simple pressure switch.
Go here for more info:
http
Good on ya,
Goober Dave
