Autodesk Map 3D 2007 - MAPUICMDPICKSET Annoyance
Hi All,
I recently started with a new company, and their CAD standard is AutoDESK Map 3D 2007.
I have an annoyance that I don't know how to get rid of.  Everytime I pan, or zoom, when I repeat the last command (i.e. right click), it tries to repeat the command MAPUICMDPICKSET, rather than the last active command I had (like drawing a line).
Is there any way to get around this?
Thanks...
RE: Autodesk Map 3D 2007 - MAPUICMDPICKSET Annoyance
Yeah.  I wish I could upgrade, but sadly our organization does not have the latest SP.  Any way around in the version I am using?
The SP is just a downloadable file - see www.autodesk.com/map-support (Data and Downloads). Or - if your company policy forbids to install updates - use the padlock (see the Tip).
Vladimir Michl, http://www.xanadu.cz
