Case Drain Flow?
Case Drain Flow?
Hi
Anyone know typical flows for case drain for a hydraulic motor?
Specifically, we have an end product with a hydraulic motor of unknown origin. The product maker is in the UK, and I am having trouble getting in touch.
The motor is bi-rotational, 20cc/rev, ~10 GPM max flow. A port is #10, B port is #8, and the case is also #8.
I am designing a manifold for a series of these products, and space is a premium. I do not have experience with CD flows. I would like to the CD ports to be #4.
Any rules of thumb?
thanks!
Any rules of thumb?
thanks!
RE: Case Drain Flow?
Most standard shaft seals are only rated to about 5 BAR(73PSI).
Maytag is correct, there are many variables that can effect casing drain. Some manufacturers used to publish their drain figures. Most have stopped because they cannot cover all of the possibilites and it leaves them open to warranty issues.
I'm in the UK, who is the manufacturer and what type of motor is it. Obviously piston, radial or axial, bent axis possibly?
Adrian
Ed Danzer
www.danzcoinc.com
www.dehyds.com
-if this is an open loop application, then maybe design for case drain max 10% of flow. That would be a fairly sick motor, as there is much leakage port to port that doesn't end up in case.
-if hydrostatic, it depends on the charge pump of the pump, and the flushing/shuttle package. How big is the charge pump(s), how much of charge flow is taken out at pump vs. how much taken out at motor. Then, it's also more of a constant rate. Increasing leakage from wear means decreasing from flushing so it's more constant.
kcj
These motors are bent axis. the end products are thrusters (SubAtlantic is the maker) for an ROV. System pressure is 3000psi.
Ours is a closed system. Instead of a charge pump, we use spring charged bladder compensators (~15 psi) as our "tank". the CD on the manifold is basically instead of a bunch of Tees at pump intake.
We are filtering the return flow, before the compensators. The CD is not filtered. we are filtering the high-pressure output of the pump.
cheers
Are you expecting the system to generate or take in contaminants? If not, one of the filters, the one with the biggest micron rating, is not working?
I have looked at Sub-Atlantics web site and I see the application would suggest that one of the filters is to absorb water.
The images on the data sheet show motors that look like Parkers F2 motor, however Sub-Atlantic sell conversion kits to fit many standard motor flanges. That means that the motor could be one of many models.
The ports are,as you say #8(1/2" BSP). You cannot reduce the port size to #4(1/4" BSP). If you do, you will surely blow the shaft seals on the motors. The casing drain ports is sized acording to the amount of oil flow that the manufacturers expect to see. Reducing it will force the case pressure up. If you have have two motors, the port in the manifold needs to be #16(1" BSP). If you have 4 motors you will need #32 port(2" BSP).
You cannot cut corners, if you refer to any bent axis motor data sheet you will see that it says the casing drain must be piped seperately using the correct size piping. If you do anything less, it is only a matter of time before the shaft seals are blown out. Don't be guided by what people believe the flow may be, follow the size of the casing drain port on the motor. That way if there is a failure, there will be some warranty support.
If you give the motor manufacturer a get out, they will take it.
This is my experience from buying, designing, selling, servicing and maintaining marine hydraulic and industrial systems for 20 years.
Ultimately it is up to you to decide what to do, but if the motors start spilling oil, fingers will start pointing in your direction as you are the person who designed the manifold. From experience it is not nice when environmental investigators start asking difficult questions.
Good luck
Adrian
We are using a filter cart with water removal filters on deck as a maintenance procedure.
Good point about the warranty issue. My only caviot is that these thrusters will not be used in an industrial situation (dives will be for a few hours, a couple times a week). As i understand , high CD flows occur as the motor wears. I truly don't expect much wear on the motors. but that is indeed difficult to quantify. I am planning on using larger ports as opposed to #4.
that said, flow is directly proportional to area, which is proportional to the square of the diameter. to keep the same flow velocity using 3 #8 as input into the manifold, a #14 (hard to find) would be adequite.
thanks all!
When selecting the port size, bare in mind the pipe fittings. The holes through the middle of stud fittings can be considerably smaller than the threaded port. Welded SAE flanges are sometimes an alternative.
All motors leak oil into the casing. Brand new motors leak less the old ones, they still leak. The higher the working pressure, the more oil you will have through the casing drain. The higher the viscosity, the higher the pressure drop accross the casing drain.
The duty cycle of the motor is not really relevant. If the casing pressure is spiked, the shaft seals are the weak point and they will rupture. Whether working for 2 minutes or 2 days, if the casing pressure goes too high you will have a mess.
I have done loads of work for US Navy and USCG applications. Whenever hydraulic oil was mentioned, the envioroentalists got really twitchy. I don't envy you with this one.
Good luck
Adrian
All that said, I once worked on an application on a winch on a Korean mine hunter. Someone from the Korean navy though it would be a good idea to put a shut off valve in the case drain line.
The casing pressure wss recorded at 350 BAR before the motor exploded. That was a good quality shaft seal.
Adrian
I rarely use filters on case drain lines, due to the pressure drop issues. Typically we run case drains into a manifold, (with a connection to tank) then draw from that with a pump larger than expected case flows. That pump pushes oil through the cooler and filter package. No back pressure on case drain, in fact it needs to be tested to make sure not going negative pressure. Say a charge pump is 10 gpm into drain, we may pull 15 or 20 gpm from that manifold and send to the cooler/filter loop. Then 5 to 10 is always coming from the tank line to the manifold. Ultimately, case leakage could go to the full 15 or 20 gpm without ever going backwards back up the suction line into the tank. Still gets filtered and cooled, but minimal back pressure on seals.
k
