braced frame
braced frame
Hi. I am designing a fairly large elevated platform to support heavy mechanical equipment. The platform falls into design category D. Because the platform is less than 35' tall, I am using ordinary concentrically braced frames for vertical bracing. However, the platform does not really have a diaphragm - just open bar grating. So I need to provide some horizontal bracing to get the forces from the units to the vertical bracing frames. Does this horizontal bracing also need to meet OCBF requirements.... seismically compact, connections designed for RyFyAg, etc... Normally, I've seen angles welded to the beams under the grating. Thanks.
RE: braced frame
