Circuit Switcher vs Circuit Breaker Pros and Cons
Does any have any document showing pros and cons of using Circuit Switcher vs Circuit Breaker?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Circuit Switcher vs Circuit Breaker Pros and Cons
CB - has CT's, faster clearing time (for GCB, could be slower for OCB at low fault levels), roughly the same cost (10% depending on how many CT's and/or trip coils), w/CT's provides protection for power transformer tank-mounted arrester failure or high-side bushing failure.
C/S - less expensive, can have integral disconnect switch, may take up less space (candlestick versions) vs. CB.
For power transformer protection, given the increasing costs, lead-times and asset values I'm going to specifying all CB's for protection on power transformers. The only time I'll use circuit switchers is when I have space restrictions or I have bus CB's for backup protection available at the specific site.
Others?
Thanks for your response. It is my understanding that Circuit Switchers come in handy whenever frequent switching is required. Also, I believe they are rated for lower amp usage and have lower interrupting ratings as well?
However I admit that it didn't even occur to me that mounting CT's would be an issue, but it makes sense. I wonder if using a Southern States CMD CT would solve this problem.
Once again, thanks for your valuable comments.
I will wait to hear from others as well.
zazmat
Also, the CMD while an interesting technology, has its own unique issues that may or may not be a problem that has to be considered against any CT mounting issues.
