Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
radger49 (Structural)
7 May 08 22:56
Is it possible that the steel column section on the upper floor is bigger than the steel column section on the lower floor? The building is irregular in shape, 7-storey with two cellars/basement, perimeter of the cellar is a concrete wall and columns, and other structures are steel columns and beams, with auto-select steel design, I encountered this, steel columns on 2nd floor is much bigger than the steel columns on the lower floors. And also, is there a way to incorporate CMU wall system in analysis using ETABS, could someone help me in this matter, thanks so much!
slickdeals (Structural)
8 May 08 12:54
It could be because there is no column above to distribute the moment.
8 May 08 19:25
Thanks for your immediate reply, but then the column I mentioned has columns in its upper floors.
Close Box
Join Eng-Tips® Today!
Join Us             Close
