AutoCAD Title Blocks For ProE
We have some title blocks drawn in AutoCAD that I would like to use in ProE. Can you import AutoCAD formats as ProE formats or do they need to be recreated in ProE?
Thanks in advance for your help.
RE: AutoCAD Title Blocks For ProE
You can include Pro/E reserved parameters like &model_name, ¤t_sheet, &dwg_name, &scale and your own parameters like &material, & mat_spec, &heat_treatment, etc.
Would I create a ProE "C" title block file and import the AutoCAD "C" title block and then save the format file? Sometimes when I import a file into a ProE drawing, it always says the file is not the same size as the current file. Wouldn't the AutoCAD "C" format be the same size as the ProE "C" format?
