ASME Code Stamp Required ???
hello all,
I have asked this question before (in other forums) and gotten a variety or responses, none satisfactory....
My question is about a new component in a process facility. I am not sure if it will require an ASME Code "stamp" and National Board Certification or not...
The "tank" (really a reactor)is 6 ft dia. 10 feet SS and operates at a maximum of 12 psig. However, it also has a half-pipe jacket that will operate at about 100 psig (400F).
The tank will have a modest vacuum of -10 inches WC....
The "tank" will be designed and constructed to ASME VIII - Section I.
My question is this: Does the jacket pressure/ temperature require this "tank" to be a stamped, ASME vessel ? If so, can someone point me to the chapter, verse, and/or code case that confirms this ???!!
MJC
MJC
RE: ASME Code Stamp Required ???
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
Yes you need atamping if the 100psi jacket has a crosssection of bigger than 6 inches and press >15psi
read the preamble of Sec VIII-1 it is very clear.
Elmer.
There is also another important point: the effect of 100 psig jacket pressure on the reator wall. That is, your vessel will not only operate at 12 psig internal pressure, but at a 88 psig EXTERNAL PRESSURE(100 psig - 12 psig).
As far as I remember (I do not have a Code Book handy) Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig, but less than 3000 psig. Therefore, this vessel must be stamped.
I hope this comment will hepl you.
Regards.
JFY
