Plastic material which is permeable for IR (infra red) signals
As mentioned in subject - Can anyone tell me what plastic material shall I use for device with IR antena(reciever)?
thx in advance
thx in advance
RE: Plastic material which is permeable for IR (infra red) signals
TTFN
Iirc, tv remote sensor windows are acrylic (PMMA). IR transparent dyes are used to make them black/dark grey.
As IRstuff mentioned, very frequency dependant.
Cheers
Harry
PMMA: http:
PE: http:
Other polymers are there too.
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
By IR - I mean "Infra Red".
I`haven`t got direct fraquency value yet(till this moment I do not know which exactly type of antena-receiver will be choosen).
However I do know that all types range from 30 kHz to 56kHz
IR is in the THz range and ultrasonic is above about 20 kHz
N.B. This is normally called near IR, which extends to around 3000 nm. At that point, it's referred to as mid or medium IR. Each requires vastly different materials and devices.
TTFN
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
further details are :
The modulation is at 38khz, but the wave length of the IR is 950nm
I spoke with consultant from Basf already and he suggested me to consider Terlux(MABS)material.
I spent some time on investigation among existing parts. I noticed some parts which plays a role as glass between two houshould are made by PC(these parts hide IR antena and diplay of chanels).
Is there serious condition to consider between use such PC material between other - ABS, MABS - for little housing design?
The question
PC has brilliant impact resistance and very bad chemical resistance (it will shatter if you expose it to solvents or cleaning agents). PC has poor flow and thus is not great for thin walled parts. PC has very good HDT.
MABS has good impact resistance and chemical resistance. Good flow but lower HDT. The impact modifier in MABS is butadiene based so it is not suitable for use outdoors because sunlight will attack it.
Price per unit volume is about the same. PC is cheaper per kilo but has a higher density so you have to adjust the price for the density.
The neat thing is how to paint such material to be less transparent for human eye, and still well transparent for IR.
I am close to accept MABS compound becouse of its good conditions for filling small areas.
But, why does it matter what the eye can see if it can't see 950 nm at all?
TTFN
As I said - I need a material transparent for Infra Red, but in parallel it should be les transparent for human eye to hide what is covered inside.
Guys, please excuse me but I am not a material engineer at all so I do know I would sound as total newbie, which in the end I am
If I were inclined, I would simply take it apart to see what's inside, in any case.
TTFN
The gentleman may want the parts behind to be hidden for aesthetic reasons. A normal user of such devices would not be inclined to see what is inside so would not take it apart.
The gentleman asked how to make it transparent to near IR and opaque to visible light.
Maybe a bit late to help but try Makrolon 2805 or 2405.
I am not sure how they do it but the variants have been developed specifically to transmit near IR and block out visible light.
The spectrum graph for the two variants I suggested suggests theat in the visible light range transmissivity is as follows:
2805
Wavelength: <700nm, transmittance: 13%
Wavelength: >700nm, transmittance: 90%
2405
Wavelength: <700nm, transmittance: 2%
Contact BayerMaterialScience for more information.
I have the manual at hand now but cannot scan the page and the graph, so I will quote word for word the text.
Quote
"Bayer Thermoplastics Technical Ring Binder.
Makrolon Propertes 2
2.1.1.2 Optical Properties
A knowledge of the optical properties of Makrolon is of considerable importance for it's applications in lighting engineering and optics etc.
The graph in Fig. 1" (not scanned into here) "gives a general idea of the transmission of Makrolon in the ultraviolet, visible and infrared ranges.
It can be seen that in the ultraviolet range light is absorbed totally with wavelenghs of up to approx. 275nm.
The light transmission the increases progressively with the wavelength, reaching a value of 85-89% at the beginning of the visible range above 400 nm; it then remains more or less constant up until the beginning of the infrared range. The light transmission diminishes with increasing wall thickness."
Makroln 2800 is a medium to high viscosity injection moulding grade.
Makroln 2400 is a medium to low viscosity injection moulding grade.
The 5 instead of a 0 for the last digit of the code indicates an additive to enhance mould release.
Makrolon is Bayer's trade name for their polycarbonate. There are probably now about 20 manufacturers of PC (polycarbonate) throughout the world. Lexan by GE is the other long standing well recognised trade name.
PC was mentioned as a possible material very early in this thread by Demon3 who is someone with excellent knowledge of the subject.
Dyes opaque to visible but transparent to IR was mentioned by Pud in a very early post. Pud also has a very good knowledge base, especially on processing, but also on available materials.
That is how Bayer, or anyone else makes their PC or any other normally transparent to visible light plastic opaque to visible but retain their IR transmission characteristics.
Natural colour PC is reasonably transparent to some parts of the IR spectrum, especially in the 700 to 1600 nm range where it transmits about 80% in thin sections.
To do his right you need to know:-
1) The specific spectrum of the light to be transmitted.
2) The transmission of the naturally coloured plastic in that wavelength band.
3) The transmission of dye formulation in the visible and IR in that wavelength band.
Any previous sarcastic remarks were intended to discourage a response that required this type of reply to refute misinformation. Obviously it did not work.
End of lesson.
I forgot to credit IRstuff's very relevant and knowledgeable contribution re wavelength band also.
That said, they are usually sufficiently dark enough to prevent the average person from seeing through the window into the circuitry. That said, anyone truly interested in the circuitry will simply remove the cover, or, use a NIR configured-camera to see inside.
TTFN
Translucent is transmission with light being scattered so that form cannot be seen, such s frosted glass.
Clear means al light passes straight through with no scatter.
Colour means some parts of the spectrum of visible light is absorbed and some passes through or is reflected.
A coloured tint is when some part of the visible spectrum is transmitted, like sun glasses.
IR receiver lenses are normally a dark red tint with quite low transmission of visible light, but good transparency of IR light in the required wavelength band, but they could be clear or opaque at visible light wavelengths either by the natural colour or opacity of the base resin or by an colour od dye or pigment that is still transparent in the required IR wavelength band.
"Can anyone tell me what plastic material shall I use for device with IR antena(reciever)?@
Followed by:
"it should be LESS transparent for human eye to hide what is covered inside."
I therefore suggested a material that would fulfil this criteria, in the belief that this would give the questioner an option to look into, and that if they required more information to contact Bayer.
I did not imply that I knew everything about it or that that is the ONLY material to use. In fact I suggested the opposite, that I have limited knowledge of the subject. The last thing I intended was to tell the questioner what to use. They should make up their own mind based on as much information that they have available.
If it is for secrecy resons then yes, a fully opaque material (to visible light) would be more appropriate.
I had also seen that PC was mentioned earlier but I thought I would add some additional information. Now further information has been added by other posters it is even better.
I suggetested the poster contact Bayer as they would have received exactly the information that you posted and that I have in front of me.
I find it good practice to not recommend brand names unless there is no option. I also find it good practice in a "non commercial" technical only forum to recommend several prominent suppliers or a variety of suppliers.
I also try to avoid such lengthy replies unless necessary. Sadly this case became necessary to refute incorrect information.
I also try to aim my reply to the OPs level. In this case he was obviously a bright and competent technician with a decision outside his normal experience. He had done his homework and only appeared to need guidance not high level of detail. He was obviously English second language, so easy to read answers were required. When asked for missing information, he always provided it so he could be trusted to follow a lead without spoon feeding.
