Visual Basic/SolidWorks running a SW macro from VB
I would like to run a SolidWorks macro from VB.  Does anyone have an example?  The drawing I want to modify is already running and the macro is saved in app.path.  When
I try to implement the macro within VB it does not work.  I just need a way to call it from VB.
Josh
RE: Visual Basic/SolidWorks running a SW macro from VB
NEVERMIND
Josh
Nevermind? Did you find a way to implement this? Or are you just trying it a different way?
rocheey
At first I was unable to run the code from my visual basic program, but I made some modifications so it would run
in the program and not just in the SolidWorks API environment.
Josh
But if anyone could give a sample on running a SW macro from VB I would still appreciate it.
Josh
' I put this code in: "C:\Program Files\SolidWorks\Macros\" and call it: "TitleBlock.swb" Then I set a macro key to Ctrl F12. The VB program called "Titleblock.exe" will run.
Dim swApp As Object
Dim Part As Object
Dim Gtol As Object
Dim FeatureData As Object
Dim Feature As Object
Dim Component As Object
Sub main()
    ' Start the application and activate it
     MyAppID = Shell("J:\@Engineering Central\Common\Applications\SolidWorks\Executables\Titleblock.exe", 1)
End Sub
Bradley
