Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just wanted to let you know that I registered today, and your site is fantastic. I found solutions to problems that I have been encountering for months!..."
Geography
goldnwhite (Mechanical)
6 May 08 15:09
We have an elevated walkway that is accessed from the top of a tank. You climb down to the walkway to access some valves that are located there. Are there any codes/requirements for an additional means of egress from this walkway should something occur atop the tank blocking the only means of egress?
In the NBIC for boilers/pressure vessels, the installation requirements state: "There shall be at least two permanently installed means of egresss from walkways, runways, or platforms that exceed 6 ft. in length." Was this requirement adopted from some other code or is there a similarly stated code available? This application is not for a boiler house, but a process tank located outside.
Helpful Member!  MJCronin (Mechanical)
1 Jul 08 9:33
goldy....
Suggest that you review the NFPA "life safety" codes and rules.
Try this:
http://www.nfpa.org/catalog/product.asp?category_name=Built+Environment&pid=101B02&;target_pid=101B02&src_pid=&link_type=category&src=catalog&cookie%5Ftest=1
I seem to remember that, for areas that are not commonly occupied, only one means of egress is permitted, but it cannot be too far from a "main accessway"
The key here is "not commonly occupied", a category in which your valve station seems to fall
This is helpful too:
http://www.workplacegroup.net/article-rev-egress.htm
Star ????
-MJC
Close Box
Join Eng-Tips® Today!
Join Us             Close
