thread locker
thread locker
does anyone know any kind of thread locker that can be used on anchor bolts and how? thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: thread locker
Personally I prefer to have my bolts embedded in the finished concrete, or to add a lock nut (second nut). I don't trust any of the chemical products to be 50 year plus reliable.
I'll be very keen to see what others post!
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
RE: thread locker
RE: thread locker
RE: thread locker
RE: thread locker
RE: thread locker
RE: thread locker
If you're in a seismic area, I can understand your hesitation. Crimping the threads is the best way to go, as long as a permanent solution is desirable. In french we would call it "defacing" the thread, but no matter what it is called, if you deform, destroy or otherwise marr the thread your bolt isn't going anywhere.
I have often thought that if I had nearly no thread, I would ask for the interface between the top of the bolt and the top of the nut to be v-punched to cause a defacing. I'll post a sketch of what I'm thinking if I get the chance.
Cheers,
YS
B.Eng (Carleton)
RE: thread locker
Gall the threads above the nut or use double nut.
RE: thread locker
I think we need a dictionary of standard structural terms to be put out by the ISO.
Cheers,
YS
B.Eng (Carleton)
RE: thread locker
DNBEA, if by Loctite you mean the adhesive, it looks like it is just for sealing the threads. You can still remove the nut with a tool.
A tack weld is best. Don't worry about hardened nuts and all that other stuff. The little bit of heat generated by a tack weld will not change the metallurgy to any significant degree. All you need is a little bead at the inside rim of the nut to the edge/end of the anchor.
RE: thread locker
Your can check the Loctite website or with their representatives to get a recommendation for your specific application.
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
RE: thread locker
RE: thread locker
My personal preference is for locknuts
- I do not like loctite (being a structural engineer I trust physical methods over chemical ones)
- tackwelds make possible future replacement difficult. Having worked in two retrofit projects I tend to be a bit more sensitive to it.
- Damaged threads will prevent the nut from falling off but they will not prevent the bolt from becoming loose.
RE: thread locker
this is on the AISC Solutions Center:
6.5.1. What can be done to prevent the nut from loosening?
In general, when properly installed, the high-strength bolt-nut assembly will not loosen. When snug-tight bolts are used, the loading will be such that loosening of a nut will not occur. When fully tensioned bolts are required, as for slip-critical connections subjected to vibratory or fatigue loading, the installed tension and the attendant friction on the threads will prevent the nut from loosening.
In some other cases, such as nuts on anchor rods (for which full-tensioning is generally inappropriate), further consideration may be required. In such cases, an additional jamb-nut or second nut may be provided. Alternatively, the threads can be spiked or marred or the nut can be tack-welded to the base metal to prevent it from turning. Note that the latter two solutions are permanent actions. There also exist proprietary nut devices with locking features to prevent the nut from backing off.
