Instances of Configurations on BOM
   I am inserting two instances of a routed cable into a box.  The two cables are indentical, but as installed, the routing is different.  They are separate assembly configurations.  Is there any way I get these onto the same line on the BOM with a quantify of two?
   I have fasteners on the drawing which are separate instances and configurations of the same file.
   I am using design tables to control the configurations, so there is no problem creating identical BOM entries.
                         JHG
RE: Instances of Configurations on BOM
smcadman,
   Thank you.  I tried that.  It works for every file attached to the assembly, including the ones where the configurations really are different.
   This could be an enhancement request.
                 JHG
True, true!  Configuration grouping option should have an override on the part/subassembly level, similar to the "don't show child components when used as a subassembly" checkbox in config properties.
-handleman, CSWP (The new, easy test)
