Make 2 Profile Sweeps on 1 Helix
Good morning. I am trying to make a model of a hose with an inner core liner. The model is a coiled hose and so I am using a helix and I can sweep either the core profile and the braid profile, but not both even if they are in the same sketch. There are a dozen different versions of this model and 3 different size hoses, so the helix will be changing to fit larger hose od's. Any suggestion on what I am doing wrong? Thank you in advance for any assistance.
RE: Make 2 Profile Sweeps on 1 Helix
For each sweep, do not use the helix curve. Make a 3D sketch, copy the helix using "Convert Entities", and use the 3D sketch for your sweep path.
