Ground detection device to break circuit
I'm looking for a power input module or relay type device to break power supplied to our machine if no ground is detected. Would a GFIC wired inside the machine help in this situation?
We've recently been suppling machines to China and the Pacific Rim and have had issues with RS-232 communications due to no ground or circuits with high ground potential. Looking for something rated at 10A 120/230VAC.
Chad
Chad
RE: Ground detection device to break circuit
A device like: http://www.l-com.com/productfamily.aspx?id=827
Keith Cress
There are devices such as the following that will detect ground continuity. I'm not sure how they work or if it could be integrated in a tool.
http:/
SE-525 Earth-Leakage and Ground-Integrity Monitor
A PDF version of the manual is available here.
Are 8-A output contacts sufficient?
Cory Anderson
http://startco.ca/
