turn on instance geometrie
Can I turn on instance geometrie in the sketcher for instancing, NX504?
thx in ad
thx in ad
RE: turn on instance geometrie
From within the sketcher you can mirror about and axis, which is a special case as dimensions can be applied to span the symmetrical elements (i.e. like a diameter or and overall dimension).
This covers just about any case you should need to create most kinds of geometry. You may disagree that it doesn't do so the way you first thought of, but it still works just fine.
Best Regards
Hudson
Ryan McVay
