High Impact Polystyrene taste
Does anyone know of a material similar to or a variation of high impact polystyrene that would pass a taste test and be FDA or NSF approvable? The main concern is dimensional stability in the injection molding process. The part is a flat disc with a slightly recessed center disc.
RE: High Impact Polystyrene taste
Check out a material called Isoplast by Dow Chemical.
I know what you mean about the styrene smell!!!
Live Aloha
Frank M.
Tradewind Resources
http://twrusa.tripod.com
