Calculating Mating Force for snap fit
Are there any formulas to calculate the Mating Force with friction when the part has an angle as shown in the picture below.
http://im g147.image shack.us/i mg147/8291 /snapfitan gelwh2.jpg
I haven't found any formulas which takes a angel like that in to consideration
Any answers are appriciated!
http://im
RE: Calculating Mating Force for snap fit
http:/
http://we
There are two types of collets, open and closed. The closed is modelled as a statically indeterminate beam, but otherwise operates the same. I've seen this problem handled as a circular beam in bending, Roarks also has some discussion on this with formulae in the table.
Also try the various oilfield technology companies website or forums. This is a typical application for downhole completions, packers, landing equipment, nipples, etc.
Good luck with your search or research!
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
ht
Ted
