Laptop suggestions
Laptop suggestions
Well my laptop took a dump over the weekend and now I am forced to fix it. That is not really the problem, the main issue is I just go a new hard drive installed 3months ago! Needless to say i'm in the market for something that can handle my workload. Currently I have a really "cheap" ACER laptop. Its only 2 years old and like I said on its 3rd hard drive. Do any of yall have any suggestions? If it was a perfect world I would ask for a tough book, but the boss already said he wont approve a 3k laptop. I don't think I need anything too fancy, just something that can handle the usual Microsoft office tools, AutoCAD 2008, DNC for CNC programming, Master Cam, a program for our FANUC robot, and another programming program. DAMN! Maybe I do need something special? I must have a laptop since I connect to most of the machines to make changes/back up info and because my office is across the street from where anything I work on is. Well have at it what should I get?
RE: Laptop suggestions
The best way to test something is to squeeze it, slowly, until it breaks!
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Had it two years, it works very nicely.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
ht
http://con
I doubt you will find a decent laptop for under $1K
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
Thank you all for the suggestions.
Cheers
Carlos
- IBM/Lenovo Thinkpad X61t
- Fujitsu Siemens Lifebooks T5010 and T1010
- HP Pavilion TX2550eg
- DELL Latitude XT
- mySN TSN120R
I know that there are a few above this price segment but I will not be able to push much more than $1600 through the budget. So are there any experiences with the mentioned ones? Or do you have further suggestions?
No one has mentioned serial ports yet. Considering the number of things you need to connect to I would think that could be important. RS-232 - USB converters are often more trouble than they are worth: get one built in.
Mike Halloran
Pembroke Pines, FL, USA
