any reason to update from 2006 sp3.4 to 2008???
wondering if anyone has seen definite reasons to upgrade from 2006 sp3.4 to current 2008 version.  all versions have their problems but we seem to be working just fine.  did not load 2007.  our biggest problems are speed & memory issues as always.  thank you!!!
RE: any reason to update from 2006 sp3.4 to 2008???
Upgrading should depend on: are new feature you require to get the job done, to keep up with your customers, and to keep up with your competitors.  Upgrading +3yr old computers is a cost of doing business.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Read the What's new Guides
http://files.solidworks.com/Supportfiles/Whats_new/2008/English/whatsnew.pdf
http://files.solidworks.com/Supportfiles/Whats_new/2007/English/whatsnew.pdf
What do your vendors and customers use?
Be prepared to upgrade your hardware if it is +3 years old as MadMango points out.  Hardware upgrades are the cost of doing business.  The newer Core 2 Duo Intel's are far, far superior to the older P4 Intel CPU's.  You will re-coup your cost quickly with up to date hardware.  SW2008 uses more system resources then SW2006.
For us the upgrade to newer versions of SolidWorks is a no brainer.  The product has new features that make our work easier.  We also want to be seen as using the most up to date tools with our many customers that are using SW2008.
FWIW,
Anna Wood
SW2008 SP3.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
I know what you mean, bsa11, apart from the isolate command and a couple of other things, 2006 has been the most stable release for us by far.
Cheers,
Simon
thanks for all the replies.
i think we will upgrade hardware in the future.
then it would be a no brainer to upgrade.
thanks again!!!
