mating threads
mating threads
mating threads
I need to mate threads, outer with inner, both Cut-Sweep along a Helix on outer and inner cylidrical faces. Coincident does not work. Any idea how to do this?
RE: mating threads
try tangent.
-Dustin
Professional Engineer
Certified SolidWorks Professional
RE: mating threads
Create a circle sketch on both and mate concentric.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
RE: mating threads
I need a "real thread mate" meaning a full turn (360 deg)of one part in relation to the ather around their common axis should result in their linear move by the thread pitch. Neither tangent nor coincident of the corresponding thread faces worked.
RE: mating threads
Your links don't work.
Are you trying to animate the thds? Is it necessary to detail the thds?
Try add a temp axis thru the center.
Chris
AutoCAD 06/08
RE: mating threads
Have you tried the Screw mate in the [b]Mechanical Mates[/]b section? It's not great for thread alignment but can usually be made close enough.
cheers
RE: mating threads
Perhaps you could use two configurations: one as a start position where the parts are constrained and aligned using the x,y,z planes, and a second configuration where those mates are suppressed and you use the screw mate CBL suggested.
Harold
SW2008 SP3.0 OPW2008 SP0.1 Win XP Pro 2002 SP2
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
RE: mating threads
maybe create an axis for both parts.  Mate the two axis coincident.  As far as the rotation goes... try the cam mate.  Also look into the screw mate as CBL mentioned... I have not used this functionality.  You may also be able to use a gear mate to simulate the rotation.
-Dustin
