Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is a very good site. Please keep it running. Thanks and wishing a great health and success for the site and its owners..."
Geography
Equivalent Heat Generation per unit volume for Electrical ConduitHelpful Member!
shan0124 (Mechanical)
10 Jul 00 14:40
I am trying to create a spreadsheet or find a closed-form solution to determine the heat transfer rate, flux, and heat generated per unit volume for a cross section of an electrical conduit which consists of multiple copper conductors surrounded by various layers of insulating material. If possible, I would like to determine the material properties for a single theoretical material that would have the same heat generation and heat transfer properties as the actual electrical conduit. The conduit has a variable number of conductors and insulation thicknesses, so being able to solve for a theoretical material with a similar heat signature would greatly simplify our FEA analysis. It seems to me this must have been tried by somebody else before. Anyone out there have any ideas?
DonLeffingwellPE (Mechanical)
10 Jul 00 16:13
Are you trying to find the steady state temperature distribution based on current flow through one or all of the conductors?
Don Leffingwell
Helpful Member!  shan0124 (Mechanical)
10 Jul 00 16:30
There is current flow through all of the conductors, [which is known] and the analysis is for a steady-state condition.
jobeth (Mechanical)
11 Jul 00 10:26
Check EIA Standard RS-214 "Method for Calculation of Current Ratings on Hookup Wire" (November 1958), I have developed a Mathcad worksheet to illustrate this recommended practice for calculating the current rating for a single wire. There is much literature on the subject. Good luck. Bill B.
William H. Bernhart, P.E.
I work as a development engineer for AMP - Tyco Electronics located near Harrisburg, PA. I help design interconnections and electrical connectors for aerospace applications.
Close Box
Join Eng-Tips® Today!
Join Us             Close
