Interpret German HT requirements
I have a German drawing calling out a heat treament requirement. I think it is based on the Vickers scale. It is a large centering ring for a hub that helps keep a shaft centered while in the hub and the ID of the ring is hardened to resist wear.
The drawing has 740 #40HV then beneath that it says Eht 2 +0.5
Is that case depth of 2mm to 2.5mm? Is that a Vickers of 740 using a 40 kg weight to determine hardness?
In German it says: "vorgedreht zurn Aufkohlen und Härten einsatzgehärtet und angelassen" showing an area outlined.
Another line says "geschützt vor Aufkohlung" showing an area outlined. I am guessing it means protect from carburizing.
Thanks for the help.
RE: Interpret German HT requirements
Yes, you need 740 HV to a depth of 2.0 to 2.5 mm.  I suppose the 40 is 40 kg, but it isn't written correctly.
Vorgedreht means rough turned.  Zurn is not correct - it is zum.  Aufkohlen means carburized, härten means hardening, and angelassen means tempered.  I think this means to rough turn the part up to the region that has been carburized, hardened, and tempered.
Yes, the second clause means protect from carburization.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
