Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...love the site and am constantly recommending it to (selected !) clients here in ireland..."
Geography
gobir12 (Chemical)
5 May 08 9:57
I am currently working on a power plant system design and I need to determine the fuel consumption for the gas Turbine (Gas Or Gas Oil). The Turbine is rated for 50MW How do i go about the estimate. Please I would also like you to state a reference material on this calculation.
dcasto (Chemical)
5 May 08 10:40
Why do you need reference materials?  Its simple energy in equals energy out.  Now if you want the exact answer you must tell us the EXACT thermodynamic efficency of your 50MW turbine on each fuel.
gobir12 (Chemical)
7 May 08 5:59
Themodynamic efficiency of 35 %.
gobir12 (Chemical)
7 May 08 6:04
I am currently working on a power plant system design and I need to determine the fuel consumption for the gas Turbine (Gas Or Gas Oil). The Turbine is rated for 50MW How do i go about the estimate. The thermodynamic efficiency is 35%.
dcasto (Chemical)
7 May 08 8:51
hydrocarbons have typically 22000 btu/pound mass of energy  gasoil is closer to 23000 and gas about 21000.  So convert mw to btu's, find how many pounds, then divide by efficency.
TD2K (Chemical)
10 May 08 0:03
I don't have the numbers at hand but I'm sure you can get the fuel consumption at Solar's, GE's or any other gas turbine manufacturer's website.
Seems I recall seeing these in one of the trade journals when they were talking about gas turbines also so it's readily available.
The heat rate for a gas turbine is BTU/kW hr.  They do vary depending on size so you want to do some checking around to be sure you have a reasonable value.
Most heavier hydrocarbons have a lower heating value of about 18,000 to 19,000 BTU/lb so that should give you an idea of the unit's fuel consumption.
Maximpro (Chemical)
4 Sep 08 14:21
Simply take the turbine power P in MW=MJ/sec, and divide with efficiency (P/ef.= Preq) and you will get required energy of gas.
Take gas LHV (kJ/Sm3) and find how many Sm3/sec you need to achieve required turbine energy.
Take care about units Mega vs. kilo.
Close Box
Join Eng-Tips® Today!
Join Us             Close
