Copy my settings to new version of ACAD
Does anyone know how to copy my settings to the new version of ACAD.
I know how to copy my settings from one computer to another, but how to translate that to the new version of ACAD.
Is there any chance to do that?
RE: Copy my settings to new version of ACAD
I don't remember how to export the settings of Autocad R14.
ADT 2004
which versions of Acad, from & to?
what kind of commands?
lsp, arx, marco?
depending on versions, you may only want to "copy" certain routines
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Autocad 2008
2009 will detect 2007 customization and prompt you to use these settings for the new 2009 install
some older commands may not work, see if old command has been replaced with New
double check support paths on new install
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 2008
http://
Maybe it is equal...
L.
ADT 2004
Thank you.
Tools---> Options ---> Profiles
Select current profile then click export and save .ARG file
In 2009
Import profile
I have a problem with object snap toolbar...check the attach to see how it looks like when I turn it on?
Is that normal maybe?
